 how to use custom mesh object in tool? « View previous topic :: View next topic »
imcgames
PostPosted: Wed Apr 11, 2007 9:23 am    Post subject: how to use custom mesh object in tool? Reply with quote
hi! I'm new to grome and have a question.
I want to place my custom model which is from 3DSMAX in terrain
How can I add my model to Package Browser?
Thx in advance.
greedo
PostPosted: Wed Apr 11, 2007 1:35 pm    Post subject: Reply with quote
You have to export it to collada (with colladamax) and locate it in grome.
PostPosted: Wed Apr 11, 2007 1:55 pm    Post subject: Reply with quote
Right, collada appears to be quite a capable format so you shouldn't have too many issues with max and Grome.
Here's the link: Collada
Once you do that you can use the object brush to locate the file and simply drag it into your scene. It is quite easy and intuitive once you follow through one time.
I did have small issue with a scene I exported from Max. The scene was comprised of several elements which, in Max, I would considered a single item export. In collada export each item was exported rather than as a scene made up of several objects. Make sense?
Basically, I would have to place each individual object exported from Max and precisely place each on in Grome. Not too difficult in Grome as a rule, but with several objects it can become a slow process.
I have not had the opportunity to see how to solve this. If you are exporting a scene you may want to research this situation.
Have fun!
PostPosted: Wed Apr 11, 2007 2:03 pm    Post subject: Reply with quote
Hello
Yes, COLLADA exporter from Max is a solution. Grome integrates out-of-the-box (with some limitations) with COLLADA format. About the separate objects issue mentioned above, you must make sure you use a single object in max and use submaterials so the COLLADA exporter creates one single object but with multiple materials (textures).
Also, because Grome comes with a SDK, you can make a plugin so your own object (from your own engine) format seamlessly integrates with the Package Browser. Thus you can use your game resources (as they are from the game build) directly in Grome without the need of a intermediary format. Then when you export your map for the final game build you have all the geometry templates in the right paths as they will be in this final build. You can also contact us for customizations to Grome. We can provide custom builds that directly integrates with your engine formats and saves into your game structure.
Software Engineer - Grome Development
PostPosted: Wed Apr 11, 2007 5:05 pm    Post subject: Reply with quote
That certainly saves me the time to search for the answer.
Thank you, Adrian
imcgames
PostPosted: Mon Apr 16, 2007 9:05 am    Post subject: Thank you very much! Reply with quote
