 Grome 3.10 Demo masking issue « View previous topic :: View next topic »
zerowin32
PostPosted: Fri Jul 18, 2014 8:50 am    Post subject: Grome 3.10 Demo masking issue Reply with quote
I have download and install Grome 3.10 Demo to explore some of the programm features, but when I try to use selection masks (Lasso or SelBrush) I have a strange result. It seems that the masks are not attached to the zones, and when rotating camera they become separated.
I have a few screenshots to describe the problem.
Any recommendations and suggestions would be very helpful.
Thank
Alex
[/url]
PostPosted: Fri Jul 18, 2014 2:14 pm    Post subject: Reply with quote
Can you please send us a testing scene? You can just zip it and send it to support at quadsoftware.com email address.
Also please send the files from Builder/Bin32/Logs (if you are running 32bit) or Builder/Bin64/Logs if you are running 64 bit.
Thank you,
zerowin32
PostPosted: Sat Jul 19, 2014 3:43 pm    Post subject: Reply with quote
It seems that I solved the problem. I'm working on a laptop and all I had to do is run the program with Nvidia GPU, not with an integrated Intel GPU. In this case all masks in my scene are work fine.
Thank You for the quick reply.
PostPosted: Sat Jul 19, 2014 4:33 pm    Post subject: Reply with quote
I am glad to hear that it is solved, Intel graphics drivers are notoriously bad so probably it was a driver issue.
Kind regards,
