 Zone combining in v3 « View previous topic :: View next topic »
Flexman
PostPosted: Fri Jun 08, 2012 2:19 pm    Post subject: Zone combining in v3 Reply with quote
Quick question.
Supposing I have 4x4 zones but I want to overlay a single texture (a level design) over them. If I create a single zone then split using "Layer: Keep Size" then all is well. As in the below image....
If I had created the scene as 4x4 zone first and then applied my design texture it would look like this...
Is it possible to merge the material layers after wards or is it a one way process? There was some mention of combining zones for an earlier version and wondered if this could be handled another way? Just a convenience thing really.
_________________
Richard
Tricubic Studios Ltd.
www.tricubicstudios.com
View user's profile Send private message Visit poster's website
PostPosted: Fri Jun 08, 2012 5:29 pm    Post subject: Reply with quote
In your case I think you can use an importer to load your image over multiple zones and have it clipped accordingly.
The Geo Tiff importer does that. Just save your image as a geotiff (Global Mapper can do that). Make sure you indicate proper georeference for your image (Geotiff are referenced using real world geographical coordinates to indicate where in world they should cover. This is because this format comes from simulation industry where satellite images are used). You just need to make sure your georeference center of the Grome scene have the same center as you image so they match.
Then import it on your existing zone and the plugin will create a color layer for that zones and assign proper pixels to it. The image is filtered upon import so make sure you indicate proper Pixels Per Zone in the plugin UI.
Let me know if you need any support on a specific case (you can send me the data and I can try to import for you).
PostPosted: Fri Jun 08, 2012 5:31 pm    Post subject: Reply with quote
Oh, and an alternative would be to create a single Grome zone first, of lower resolution for heightmap. Assign the image to it and then use the Split tool to break the zone into multiple parts (this will also split your image layer). Then you can use the heightmap resampler to increase the resolution of each zone heightmap to the final detail (you cannot go with full res from the beginning since you are limited by the video card to the maximum resolution you can have per one zone).
Flexman
PostPosted: Fri Jun 08, 2012 8:30 pm    Post subject: Reply with quote
Thanks Adrian, sound advice as always.
_________________
Richard
