regress |
Posted: Mon Jan 23, 2012 10:37 pm Post subject: MaskGen |
Could someone provide a step-by-step of exactly how to use the MaskGen tool? When I click "Apply" nothing happens. I'm simply trying to apply one of the presets (MountainsSnow, for example) to two different color layers I've created (both masked textures). Help? |
Posted: Tue Jan 24, 2012 7:50 am Post subject: |
You can find an video example in the procedural texturing tutorial:
http://www.quadsoftware.com/movies/grome/tutorials/procedural_texturing.mov
The UI of the layers is from Grome 2.0 but the way layers are operated in 3.0/3.1 is the same.
Basically you need to first mark your masked texture layers as in use (press the red button next to them). Once they are in use they will appear inside the MaskGen tool UI at the "Layers in use" section. Next, load a tool preset or manually add your own Distribution Masks (by pressing the + button at the upper section). The distribution masks tells you how to distribute the layers mask based on altitude, slope, direction, flowmap etc. Basically you generate the layer mask (where the layer is visible) based on the characteristics of the underneath heightmap.
Now you need to assign the distribution masks to the layers in use. You select one distribution mask with left click on its label or multiple ones with clicks while you hold control key down. Once you have the distributions masks to assign to layers selected, you need to also select a layer from the Layers in use list and press the + button next to it (the one from bellow section). Now you will see the distribution masks underneath that layer. They are assigned to operate on that layer.
In this way you can assign multiple distribution masks at once to one layer and you can also operate to multiple layers at once.
Now you can press Apply button and you will see how your layers masks are affected by the distribution masks. The same can be done to colors (simple color layers, without masks) with ColorGen tool.
The assignment of distributions to layers is not saved to presets since your layers are depending on the scene (some scenes may have or not the layers) while the presets need to be scene independent. They will contain only the distribution masks.
Let me know if you still have problems.
Posted: Tue Jan 24, 2012 2:06 pm Post subject: |
Oh, and forgot to tell you, in order for in-use layers to appear in the "Layers in use" section you need to have at least one terrain zone selected that contains those layers. |
