 Normal Map generator. « View previous topic :: View next topic »
inucasoftware
PostPosted: Wed Aug 31, 2011 5:13 am    Post subject: Normal Map generator. Reply with quote
when use normalmap generator
normalmap had Crack between Zone and Zone.
How To Fix?
PostPosted: Wed Aug 31, 2011 6:14 am    Post subject: Reply with quote
This should not happen.
Can you send me a small map that has this problem? I need to know what is the exact problem since we never had this on our maps.
PostPosted: Wed Aug 31, 2011 6:15 am    Post subject: Reply with quote
inucasoftware
PostPosted: Thu Sep 01, 2011 4:40 am    Post subject: Reply with quote
use generator option
NormalMap Button -> From interpolation surface Smoothness -> Gage (Min)
PostPosted: Thu Sep 01, 2011 7:16 am    Post subject: Reply with quote
Did you tried to use the normalmap in your engine?
In Grome the normalmap when rendered as a color layer it is using bilinear filtering which at the border, of course, it gives some seams since normalmap from one zone cannot sample pixels from the neighbor zone normalmap. But inside the lighting you will be sampling normalmap with nearest (point) sampling so it will be continuous. So the seams are not that normalmap is not continuous, but due to the sampling using bilinear filtering.
If you need to sample it with bilinear filtering (for smoothing normalmap for example) even when performing lighting you will need to add a row of pixels (padding) at the border (for each normalmap add the pixels from the neighbors). This can be done only at export, it cannot be done in the editor since it would take too much. Anyway, even without padding the seams in normalmap during lighting are not visible.
