 Material Scale « View previous topic :: View next topic »
inucasoftware
PostPosted: Mon Jul 11, 2011 6:47 am    Post subject: Material Scale Reply with quote
scale : 30 * 30
Rotation : 0.0
Orientation : 90 , 90
Export
sTextureMapping *pMapping = channel.mapping;
pMapping ->scale.x; not value 30
pMapping ->scale.y; not value 30
how to calculation recover scale value?
PostPosted: Mon Jul 11, 2011 7:23 am    Post subject: Reply with quote
As the comments in the source explain, once you have an orientation in the sTextureMapping, the scaling is no longer as a repeat factor (tiling in UV space). It needs to be in world space since texture custom orientation is computed based on projection in world space.
In your Grome UI this scaling is the one in world space but because the values would be too small it is divided by 1000. So what you have in the scale member inside sTextureMapping is the correct value to be used when computing the final UV matrix.
There are various threads already explaining how to deal with this structure. You can look at these threads:
http://www.quadsoftware.com/forum/viewtopic.php?t=620
http://www.quadsoftware.com/forum/viewtopic.php?t=505
The second one even presents how to compute the final matrix.
Or you can just have a search with sTextureMapping on the forum.
Let me know if this fixes you issue.
