 Critical error.. « View previous topic :: View next topic »
baroque2k
PostPosted: Thu Apr 21, 2011 3:31 am    Post subject: Critical error.. Reply with quote
I was using Grome2.
Computer hardware has been replaced.
"Grome_2.00.34" 64bit reinstalled.
When you run the program Critical error has occurred.
I need your help.
PostPosted: Thu Apr 21, 2011 6:51 am    Post subject: Reply with quote
In case you are using newer operating systems (Windows 7, Vista), when installing the program, you need to be administrator. Then when running the program, besides being administrator, you need to right click on exe/shortcut and select Run As Administrator (this option can be made permanent by choosing Preferences after right click and checking the option at compatibility tab).
This "Run As Administrator" option is not necessary in some cases (for example when installing the program in a driver letter and folder where any user can have access).
The errors you are getting are from the fact that the program cannot create its basic files (like the console file).
baroque2k
PostPosted: Thu Apr 21, 2011 8:26 am    Post subject: Thank you for your help. Reply with quote
