 ExpOsg problem « View previous topic :: View next topic »
svv_js
PostPosted: Fri Mar 11, 2011 8:26 am    Post subject: ExpOsg problem Reply with quote
Just wondering if anyone have been able to get the exposg plugin to work in win7?
So far I'v been able to compile it (against OSG 2.8.2, as it needed the osg dll's and i couldnt fint any precompiled 2.5-versions of those).
After adding osg55-osg.dll and osg55-osgDB.dll to the plugin folder it does run. However, it doesnt save any .osg or .ive file, only images.
(I'v tried both msvc 2005 professional and express)
Anyone have any ideas on what i do wrong?
seems the problem is when saving as .ive (.osg seems ok now)...
In _DoExport, after
osgDB::ReaderWriter::WriteResult res = osgDB::Registry::instance()->writeNode(*root_transform, ascii_file_path, options);
I wrote out res.message, and it stated that it didnt find plugin to write the file
PostPosted: Fri Mar 11, 2011 4:30 pm    Post subject: Reply with quote
I don't have much experience with OSG (I've wrote the original plugin but learn only what was needed for it) but from what I can guess, most probably the OSG plugin for .ive doesn't start because it probably depends on other DLLs that are not found (for example I notice that you also need osgdb_ive.dll to make it run).
Best would be to post this question to the OSG forums. Their user will surely indicate what DLLs are needed for ive and you can recompile them and include them in the plugins folder.
svv_js
PostPosted: Fri Mar 11, 2011 5:23 pm    Post subject: Reply with quote
Thanks Adrian, you'r absolutely correct.
Was missing several dll's from osg in addition to libpng13 and zlib1. It works now... Well, sort of, it hangs/crashes and makes a mess of grome's menus and stuff, but does save the file so i'l survive until i get more time to use on it.
-Jo
