 Docs « View previous topic :: View next topic »
mgarnett
PostPosted: Wed Nov 11, 2009 10:21 am    Post subject: Docs Reply with quote
Hi All,
Does anybody know if there is a PDF version of the help file available? I'd like to be able to print it out into a manual if at all possible.
Mark
PostPosted: Wed Nov 11, 2009 10:55 am    Post subject: Reply with quote
I've previously made a PDF version of the docs but it had several issues. I will see if I can find better tools to transform the chm into pdf.
To be noted that chm are essentially archives of html files. Total Commander for example it is able to enter these files (example: have the chm into the right panel in Total Commander and then just press Control + left arrow; the left panel will be filed with the content of the chm file; you can then copy out the html files from it).
