 Some more « View previous topic :: View next topic »
Mihai
PostPosted: Sat Feb 24, 2007 6:23 pm    Post subject: Some more Reply with quote
Just another quick work in the editor. This time I've used other fractal noise parameters to create different mountains. After that I've applied the smudge brush with a mask several times to create the valleys (roads) in between the mountain peaks. I've used another vertical texture for the rock and added a shadow map to create the realistic lighting.
Mihai Daranga
