 water « View previous topic :: View next topic »
lostbetween
PostPosted: Wed Jul 08, 2009 5:53 pm    Post subject: water Reply with quote
I am very new to grome and was offline and moving during the time we switched to version 2. Can anyone give me a simple step by step for water? Thx.
PostPosted: Wed Jul 08, 2009 6:07 pm    Post subject: Reply with quote
We will have new tutorials covering water in few days. I will let you know when they are uploaded on site.
lostbetween
PostPosted: Wed Jul 08, 2009 8:36 pm    Post subject: Reply with quote
thanks!
PostPosted: Fri Jul 10, 2009 1:58 pm    Post subject: Reply with quote
We've started to upload the new tutorials:
http://www.quadsoftware.com/index.php?m=section&sec=product&subsec=editor&target=Editor/tutorials_index
2 new water tutorials are present there. More to come in the next few days.
lostbetween
PostPosted: Sun Jul 12, 2009 9:04 pm    Post subject: Reply with quote
I tried adding water the way it shows in the beginning of the tutorial, only making a white mask when I assign to selection. From the tutorial, it looks like the water is just appearing then and this isn't happening. Also tried changing the level with no luck.
http://i543.photobucket.com/albums/gg473/lolindid/grome/watererror.png
Mihai
PostPosted: Mon Jul 13, 2009 6:50 am    Post subject: Reply with quote
So when you assign the white mask the water doesn't show at all ?
Try to paint it with the brush see if there are any changes ..also make sure that the water is above the ground..in order to see it .
PostPosted: Mon Jul 13, 2009 10:21 am    Post subject: Reply with quote
Can you send me a sample map? One which doesn't show water even though you've assigned the layer? You can use my email address or if the archive is bigger than 10MB I can send you a FTP account.
Also, please send me the console.log file (from Builder/Bin32/Logs if you are using 32bit, or Builder/Bin64/logs if you are using 64bit) after running and assigning the water.
lostbetween
PostPosted: Mon Jul 13, 2009 12:33 pm    Post subject: Reply with quote
Hi, Thanks so much for such quick responses! Yeah I have looked above and below for the water and its not there. Plus I tried raising the level to things higher than 100...assuming thats what raises the level of the water.
http://i543.photobucket.com/albums/gg473/lolindid/grome/dastrinmntsnowater3.png
Adrian, I have sent the workspace file to you emails.
lostbetween
PostPosted: Mon Jul 13, 2009 12:41 pm    Post subject: Reply with quote
Oh and Mihai, I tried using the brush with both a white mask and a black one and I still get nothing.
Mihai
PostPosted: Mon Jul 13, 2009 5:50 pm    Post subject: Reply with quote
this is happen only for that scene?
pls try this:
1. make a new simple scene..with 1 zone Tle No 256 ; tile 10
2.create
3. Ctrl+A (to select it)
4. go to Modifier tab ; Procedural Heightmap ; FractalNoise ..and chose a preset..Eroded Mountain will do
5.Go to Layers tab (from the project tab create a new layer of water)
6. Assign to selection
7. From the New Water Layer window chose New Mask (and make sure that you chose a withe color for the mask) the resolution of the mask can be left on default (512x152) and from level chose 500
8. chose ok to close the window.
After this steps you should see the water in view..
If not can you tell me what video card do you have ?
Thx
Mihai
lostbetween
PostPosted: Mon Jul 13, 2009 7:34 pm    Post subject: Reply with quote
http://i543.photobucket.com/albums/gg473/lolindid/grome/mihaiwatertest.png
I see no way to check and make sure the mask is white once made. But I rolled the color slider up to white then pressed ok.
My vid card is ATI Radeon HD 2400 Pro
Mihai
PostPosted: Mon Jul 13, 2009 7:50 pm    Post subject: Reply with quote
mmmm.... ok
One more think.. can you check that you have the last driver for your graphic card pls ?
PostPosted: Mon Jul 13, 2009 7:51 pm    Post subject: Reply with quote
Rebecca, I've received your map by email, tomorrow I will try to check it on a similar video card.
lostbetween
PostPosted: Mon Jul 13, 2009 8:38 pm    Post subject: Reply with quote
Mihai:
I updated the driver, deleted the water level I created on the sample, recreated it and still nothing shown. However I do not know how to make good use of the ATI control panel. Is there something here that might help?
http://i543.photobucket.com/albums/gg473/lolindid/grome/aticontrolpanel.png
Adrian:
Thanks so much. I am anxious to be able to do this!
lostbetween
PostPosted: Fri Jul 17, 2009 2:22 pm    Post subject: Reply with quote
should I get a better vid card?
nm, I see your email now.
