 Default behaviour for applying things to swapped zones « View previous topic :: View next topic »
duke2
PostPosted: Tue Jun 23, 2009 10:11 am    Post subject: Default behaviour for applying things to swapped zones Reply with quote
Could it be made so that when you try to apply something to a swapped zone (like a texture), it unswaps->applies->swaps, each one? In the meantime, i'll see if this can be done via the scripting engine.
On a related subject, can I apply a texture to a zone without re-doing it's settings? I mean if I just want to apply that texture with the same settings as it currently has.
PostPosted: Tue Jun 23, 2009 10:32 am    Post subject: Reply with quote
We plan to add this in the future (a toggle than when you apply a tool automatical unswap - swap is performed; there are complications though with the borders of the patches).
In the mean time this can be done with the scripting or the SDK. Shape Processing utility plugin is a fine example of this, it applies various scripts on polygonal shape doing automatic swapping and unswapping. Also there is an example script that describes how to do this with minimal unswap zones in memory and in the same time to have all the neighbors of a zone in memory while processing (see GridSwapProcessing.as in Scripts/Examples).
For a layer (or more) you can change its texture by simply clicking it thumbnail. Also you can copy all the layer settings to another one by right clicking it in the Selection tab and selecting "Copy material params to" option.
In case you want to apply the same texture that you have on a zone to another, just go to Global tab and expand the layer. Then press the > button next to the texture and select Fill Selection. This will apply the layer texture and parameters to all the selected zones. The zones that already have a texture for that layer are skipped, so you need to not have a texture assigned to your new zone (or just clear its layer before doing this).
duke2
PostPosted: Wed Jun 24, 2009 11:46 am    Post subject: Reply with quote
Could you add this function to water? Right click on Water selection->Copy water settings to.
PostPosted: Wed Jun 24, 2009 11:52 am    Post subject: Reply with quote
Yes, this will be present in an update (together with fill selection for water).
duke2
PostPosted: Thu Jun 25, 2009 9:41 am    Post subject: Reply with quote
What's the script syntax for g_terrain_editor.AssignLayerToSelection when it's a Heightmap or Selection type, where they don't have parameters? At the moment i'm just giving it a param table with nothing in it but it doesn't seem to be working (the problem may be elsewhere, though).
This is what I added/replaced to GridSwapProcessing:
void ProcessCurrentZone()
   cPropertyTable tNull;
   int sLandmass = g_terrain_editor.FindLayer("Selection", "Landmass");
   g_terrain_editor.AssignLayerToSelection(sLandmass, "Selection", tNull);
   int hBase = g_terrain_editor.FindLayer("Heightmap", "Base");
   g_terrain_editor.AssignLayerToSelection(hBase, "Heightmap", tNull);
  iEditorTool@ tool = gActivateTool("Terrain.SelectionGenerator");
  if(tool != null)
      cParamValue parameter;
      tool.SetParam("Selection.operation", parameter, 0);
      tool.SetParam("Terrain.NormalMethod", parameter, 1);
      tool.SetParamString("Altitude.Params", "0", DATATYPE_FLOAT, 0);
      tool.SetParamString("Altitude.Params", "128", DATATYPE_FLOAT, 1);
      tool.SetParamString("Altitude.Params", "64", DATATYPE_FLOAT, 2);
      tool.SetParamString("Slope.Params", "0", DATATYPE_FLOAT, 0);
      tool.SetParamString("Slope.Params", "90", DATATYPE_FLOAT, 1);
      tool.SetParamString("Slope.Params", "0", DATATYPE_FLOAT, 2);
      tool.Run();
duke2
PostPosted: Thu Jun 25, 2009 11:26 am    Post subject: Reply with quote
Nevermind, all worked out.
