 COLLADA Import Errors for 3dsmax2008 « View previous topic :: View next topic »
baroque2k
PostPosted: Wed Oct 15, 2008 11:56 am    Post subject: COLLADA Import Errors for 3dsmax2008 Reply with quote
Hello .
I use Grome 1.20.24 Professional Version.
I installed COLLADA using Colladamax_305B to 3dsmax 2008.
After make terrain_zone in Grome . Do Export by DAE and did import in 3dsmax2008.
By the way, error message appears.
Wished to inform solution method.
error message
[img]http://www.baroque2k.net/quadsoftware/COLLADA Import Errors.jpg[/img]
[130] ERROR: Face count for polygons node doesn't match actual number of faces found in <p> element(s) in geometry.
[153] Warning: Polygons is empty.
[153] ERROR: No polygon <p>/<vcount> element found in geometry.
[0] COLLADA document loaded successfully.
PostPosted: Wed Oct 15, 2008 1:35 pm    Post subject: Reply with quote
Can you send me the COLLADA dae file? You can email me to licu at quadsoftware.com or if it is bigger than 5 MB I will send you a FTP account.
I will run the collada file thru coherency test. For me all the exporter files were successfully read by 3ds Max 8, 9, XSI, Maya, Blender, ColladaView. I will also download that version of ColladaMax and test it (can't remember what collada max I was using by time I've tested it).
PostPosted: Wed Oct 15, 2008 3:22 pm    Post subject: Reply with quote
After some tests I think I've found the problem. Our plugin sometimes exports some scene surfaces which are blank (have no polygons). Collada importers should ignore these but seems that Feeling Software plugins exit with error on these cases. So I've modified the Grome plugin to no longer export the blank surfaces. You can get the plugin from here:
http://www.quadsoftware.com/storage/ExpCollada.zip
Just download this archive and unpack it in the Plugins folder (inside Grome installation directory) overwriting the old plugin. Now that error should be removed. This fix will be present in the next public patch.
Thank you for your report.
baroque2k
PostPosted: Thu Oct 16, 2008 1:16 am    Post subject: Reply with quote
Tried test receiving ExpCollada.plug again but I received new error message.
In Grome . DAE export file did export creating one by tiles no (256), tile (100).
Thank you for your reply.
[89] ERROR: Face count for polygons node doesn't match actual number of faces found in <p> element(s) in geometry.
