 Brushing objects - Translation « View previous topic :: View next topic »
michaelkutzer
PostPosted: Fri Sep 05, 2008 4:16 pm    Post subject: Brushing objects - Translation Reply with quote
Is there a way to set the translation while using the Object Brush?
Thank you.
Michael
PostPosted: Sat Sep 06, 2008 7:12 pm    Post subject: Reply with quote
Do you want to set translation from the points generated by the brush (for example to put the objects a little down or up from the ground)? Sure, you can do that. You use the brush tool UI Noise settings and for translation you choose the min and maximum values to use for each axis. The brush will randomly choose a translation between these two values for each axis. If you want to use a specific (fixed) value just use the same value for both min and max. So for example if you want to put trees 1 meter bellow the ground just use 0,0 for min and max on ox, 1 and 1 for min and max on oy and 0 0 for oz.
