 Measurement tool « View previous topic :: View next topic »
jaimy
PostPosted: Fri Sep 05, 2008 6:09 am    Post subject: Measurement tool Reply with quote
Hello ~
Is there any way to measure distance in the Grome Editor?
Thanks!
Jaimy
PostPosted: Sat Sep 06, 2008 7:07 pm    Post subject: Reply with quote
We plan to add this tool in the future versions of Grome. For now you can use the Surface Pick tool to get one position from the terrain surface. You can also create (using the Grome SDK) an utility plugin that can compute the distance between various objects on the map (you can place special gizmo objects to mark the landmarks). If your measurement requirements are more complicated (example: measure distance along a curve) we can talk about an eventual customized tool for you (for details contact me at licu at quadsoftware.com).
