 parameters for legacy import? « View previous topic :: View next topic »
holger53
PostPosted: Sun Aug 24, 2008 5:18 pm    Post subject: parameters for legacy import? Reply with quote
I am not familiar with the import-parameters
I need to set for raw import of a hightmap
from a legacy terrain of TGEA.
Thanks for any help!
PostPosted: Sun Aug 24, 2008 5:29 pm    Post subject: Reply with quote
How big is the terrain you want to import (how many vertices) and also what is the height range (min and max altitude)? What size is the tile (distance between vertices) or at least what size is the entire terrain you want to import?
Also, by pressing Help in the plugin UI you get pretty much all the parameters explained. The plugin should correctly guess your RAW size if it is square, you need to indicate only the tile size and the height range.
Also, if the raw is big, break the terrain in certain number of zones so you have like 512 by 512 (or 1024 by 1024) tiles per editing zone.
