Author |
Message
GrimMoroe |
Posted: Mon Jul 28, 2008 11:06 pm Post subject: Disappearing sky... |
Hello everyone,
First off I love the program.
I do seem to have a little problem though, when I build my terrains I have a sky, but when I save them then reopen them later I don't.
When I check the sky texture in the options for the viewport the textures are there and the sky box is checked but still no sky.
Again if I create a new terrain I have the sky back again.
Any ideas?
Thanks in advance,
Phil |
Back to top |
ALicu |
Posted: Tue Jul 29, 2008 7:17 am Post subject: |
Can you send me a small sample map you saved and after reload doesn't have the sky in it (you can use licu at quadsoftware.com)? I need to have a look at it to see why the sky is not contained in your scene. Also, you can send me the console.log file from Builder/Bin/Logs after the you load the scene without sky. Thanks.
Adrian L. |
Back to top |
GrimMoroe |
Posted: Tue Jul 29, 2008 7:31 am Post subject: |
Email was sent, thanks for the quick response on this.
Phil |
Back to top |
ALicu |
Posted: Tue Jul 29, 2008 10:12 am Post subject: |
Hi, please send the MissingSky folder, too. Forgot to tell you, a scene is made of both .workspace file and its associated data folder (with the same name as the workspace file). The references to the sky are there (in the MissingSky folder). Many thanks for the report. |
Back to top |
GrimMoroe |
Posted: Wed Jul 30, 2008 8:44 pm Post subject: |
Problem is solved with the update, thanks again. |
Back to top |
