 Dont know if this is a bug. « View previous topic :: View next topic »
dyrwoolf
PostPosted: Mon May 12, 2008 12:33 pm    Post subject: Dont know if this is a bug. Reply with quote
I dont know if this is a bug or if it is something wrong with my PC, or it maby supose to work like this.
The problem is when i using alot of textures, i follow the tutorial Procedural Texturing, and when I have applied all the textures and trying to zoom in and paint with some textures brushes like in the GromeAtlas tutorials. My fps drops to around 3. But if i zoom out so i can se the whole map then the fps goes upp to 30-60 and I can paint whitout any problems.
I have tried to unswap alot of areas so i just working on 2 but that dont hel either.
When i zoom in whitout any textures applied and working with heightmap brushes I have no problem with the fps, even if work will all areas at the same time.
Sins
Dyrwoolf
PostPosted: Mon May 12, 2008 1:21 pm    Post subject: Reply with quote
What video card do you have and what driver version?
Is this happening without any editing or when you apply a brush? In case of the former situation, are you painting layer masks with MaskBrush or ColorBrush? Also, how many texture layers you have and how big (mask resolution)?
Thanks,
dyrwoolf
PostPosted: Tue May 13, 2008 3:44 pm    Post subject: Reply with quote
I have a Geoforce 7800 gtx, I downloaded the latest drivers and got the fps upp to 5-8. I use 9 texture layers. I paint with mask brush. When I unload 5 of the layers i get a pretty decent fps of 20-60.
PostPosted: Tue May 13, 2008 4:59 pm    Post subject: Reply with quote
Hi, do you have terrain LOD activated (from Options->Preferences, Terrain, Runtime, LOD, Enable for all zones)? When using multiple layers without LOD activated the performance drops.
Can you post a screenshot with a low fps?
Thank You,
