 Collada Export « View previous topic :: View next topic »
Sparticus
PostPosted: Tue May 06, 2008 5:32 am    Post subject: Collada Export Reply with quote
Is there a way to only export the selected zones with Collada, like with OSG? When trying to export a 10x10 with in Collada, I get an error when i run out of memory (2gigs) and then the program crashes. Error:
Core Engine Exception Handler
Exception C0000005 detected!
Not sure if this is considered an actual bug or a limitation of that particular exporter?
Thanks for the help !
[/img]
PostPosted: Tue May 06, 2008 6:37 am    Post subject: Reply with quote
Hi, we will add an option to the exporter to save only the selected zones. Should not be hard to make. I will post you an update soon.
For now you can do it with a trick: delete zones you don't want to export, perform export, undo (to undelete the zones), repeat etc.
And another better method would be to swap out all the zones, and then call the exporter. The exporter will swap in and out zones as it exports them.
PostPosted: Tue May 06, 2008 7:24 am    Post subject: Reply with quote
Hi, you can download an updated version of COLLADA exporter with export only selected option from here:
http://www.quadsoftware.com/storage/ExpCollada.rar
Just unrar it into the Plugins folder from Grome. Make sure you use the latest Grome version (1.20.09) !
Regards
Sparticus
PostPosted: Wed May 07, 2008 3:41 am    Post subject: worked ! Thanks Reply with quote
The new pluggin works great ! Your support is amazing Very Happy
