 Deleted Preset « View previous topic :: View next topic »
Hornsj2
PostPosted: Wed Mar 26, 2008 5:55 pm    Post subject: Deleted Preset Reply with quote
I was wondering if there is a way to restore a preset. I accidentally deleted one of the procedural texture presets and would like to get it back. Oops.
PostPosted: Wed Mar 26, 2008 6:06 pm    Post subject: Reply with quote
Hi, unfortunately not. In case it is a default preset I can send it to you.
In general it is good idea to save your presets from time to time from main menu: Tools -> Manage Tools Presets...
Also in case you want to save the entire configuration (presets, UI settings, shortcuts) you should safe the configuration.registry and shortcuts.registry from <Grome installation folder>/Builder/Scripts/Configs/default.
Hornsj2
PostPosted: Wed Mar 26, 2008 6:11 pm    Post subject: Default Reply with quote
It was the default Vertical 0 90 preset for mask generating. I basically made another one by adding two distribution masks and renamed them vertical 0 90 (1) and (2). This seems to do the same thing but I am so new to this program that I don't know what I don't know.
Thanks again for the quick response.
Hornsj2
Hornsj2
PostPosted: Wed Mar 26, 2008 6:17 pm    Post subject: Not the same Reply with quote
Well I guess it's not the same.. it appears to cover the same area as the default 90 90 preset. Could you please send me the default Vertical 0 90 maskGenerator preset?
Much appreciated.
Hornsj2
PostPosted: Wed Mar 26, 2008 6:26 pm    Post subject: Setings Reply with quote
OK i'm looking over the settings for each distribution mask and I think I might be able to figure out what the correct settings would be for a 0 90 mask. If you could still send me the height, slope and orientation settings I would appreciate it.
Hornsj2
PostPosted: Wed Mar 26, 2008 6:42 pm    Post subject: Figured it out Reply with quote
OK so this thread is all about me not knowing what I am doing again (if you saw that QuickTime post you would understand). Once I sat down and thought the settings through I figured it out.
I appreciate your quick responses on both of these inane topics. Embarassed
I love Grome so far by the way.
Hornsj2
Mihai
PostPosted: Wed Mar 26, 2008 7:33 pm    Post subject: Reply with quote
No problem Hornsj2 .
Here are the settings for vertical 0 90 presets :
- first there are 2 distribution mask for vertical 0 90
1 Height : MIN: -100000.0 MAX: -100000.0 ATT :0
Slope : MIN: 0 MAX: 90 ATT: 0
Orientation :MIN: 90 MAX: 45 ATT: 10
2 . Height : MIN: -1000000.0 MAX: -100000.0 ATT :0
Orientation :MIN: 270 MAX: 45 ATT: 10
If you have any question about : this settings do not hesitate to ask Smile
Regards
Mihai
