 Not all textures showing up « View previous topic :: View next topic »
ldemarinis
PostPosted: Mon Mar 17, 2008 8:22 pm    Post subject: Not all textures showing up Reply with quote
I am having a problem that seems to be linked to my opacity map. Simply, not all of my textures are appearing on my Atlas terrain.
PostPosted: Tue Mar 18, 2008 7:15 am    Post subject: Reply with quote
Hello, how many layers are you using? Also what parameters are you using for tree depth and how big is the terrain? Can you sent me the opacity mask? Best would be to look with a image program to see if it is right (it should have a combination of Red Green Blue and Alpha channels indicating the masks you were creating in Grome, but normalized).
ldemarinis
PostPosted: Tue Mar 18, 2008 2:38 pm    Post subject: Reply with quote
Adrian,
I have it working but I just did the opacity map work myself in photoshop. The tree depth that i am using is typically four and the size of the terrain is 4x4 zone map with a 1025x1025 heightmap.
PostPosted: Tue Mar 18, 2008 5:22 pm    Post subject: Reply with quote
Hi, what was the problem? Was it caused by the exporter?
ldemarinis
PostPosted: Tue Mar 18, 2008 5:51 pm    Post subject: Reply with quote
Well it seemed that the alpha maps were just incorrect. The base texture wasnt there at all, and the maps were inverted.
PostPosted: Tue Mar 18, 2008 5:57 pm    Post subject: Reply with quote
Do you have the latest version of the exporter? 1.1 (posted on 03/13/2008)
There was a bug that caused similar results but was fixed.
I need to know if there is a bug in the new version so I can fix it. Thank you.
ldemarinis
PostPosted: Tue Mar 18, 2008 6:18 pm    Post subject: Reply with quote
No, I do not have that exporter. I will make sure I get that. Thanks, and I will let you know if that solves the problem.
ldemarinis
PostPosted: Tue Mar 18, 2008 8:10 pm    Post subject: Reply with quote
That seemed to fix the problem. Thanks a bunch!!!
PostPosted: Tue Mar 18, 2008 8:17 pm    Post subject: Reply with quote
Another thing to notice is that this bug was happening when the sampling step (the step used to get scene data) was different than the scene resolution you are editing (tile size for heightmaps and pixels number for images is different than the outputted ones). The exporter allows this (it is pretty versatile so you can work with layers with different resolution for example, even though this case Torque cannot handle for now).
So be aware that this means that you are exporting at a different resolution than the one you are working with inside Grome. This means that you either work at a greater resolution in Grome and you loose detail at export or you edit at a lower resolution and include much more data at export than necessary.
Let me know your heightmap size, mask and color sizes and I can point the best exporting sampling steps.
