 Problem with Mask Generator « View previous topic :: View next topic »
Soulos
PostPosted: Mon Jan 28, 2008 2:49 am    Post subject: Problem with Mask Generator Reply with quote
I seem to be having a bit of a problem with grome when it comes to using the mask generator, I have a selection layer just for my mountain region, and I create a color layer with a mask. Bang everything goes transparent just like in the tutorials, however when I go to the generator, I set it up as the tutorial suggests, and I press apply then nothing happens
what am I doing wrong?
Cheers
PostPosted: Mon Jan 28, 2008 8:11 am    Post subject: Reply with quote
If your layer has a mask and it is marked "In use", it will appear in the Layers section of the MaskGenerator tool. You create a distribution mask (indicating at what altitude, angle, slope the mask will be generated), then select the distribution mask (click on its label), goto Layers section, select the layer you want to assign the distribution mask to, and then press the + button in the Layers section (above the selected layer). The distribution mask will be assigned to this layer. Then when you press apply all the assigned distribution masks will create the masks for you. You probably are missing this assignment step (which may be not that clear in the tutorials).
This system (which may seem a little complicated at first) is very versatile, allowing you to assign multiple distribution masks to multiple layers, assign different distributions to different layers etc.
If you still have issues, please let me know.
Soulos
PostPosted: Tue Jan 29, 2008 9:11 am    Post subject: It's Alive! Reply with quote
Ahhh I've got it going now, thanks, I was a little thrown by the demo. Excellent work on the response, It makes me glad to have purchased this product and have good support.
Cheers
