 Duplicate Object « View previous topic :: View next topic »
cmusch
PostPosted: Sat Dec 15, 2007 1:34 pm    Post subject: Duplicate Object Reply with quote
Hello!
Is there an easy way to duplicate an object (properties, transform and all)?
regards
cm
PostPosted: Mon Dec 17, 2007 7:36 am    Post subject: Reply with quote
Are you referring to instances? Or both instances and templates?
There is no Clone function (yet) in the SDK. For now you can manually replicate any instance or template using a code similar with that used by the storage plugins (create the instance, set its transform, etc).
For property tables there is iPropertyTable::Clone function which can replicate a table with all its structure and values. Then you need to assign it to the newly created instance.
The manually replication is pretty straightforward. If you need I can post a code snippet for it.
cmusch
PostPosted: Mon Dec 17, 2007 8:44 am    Post subject: Reply with quote
I was looking for a way for our artist to duplicate instances which have a property table set. We need several instances of similar objects, and it is somewhat cumbersome to create them all by hand.
I think I'll do what you suggested and write a "clone" plugin, but you can also consider this a feature suggestion (perhaps ship the "clone" plugin as an example?) Wink
regards
cm
PostPosted: Mon Dec 17, 2007 9:49 am    Post subject: Reply with quote
You can clone instances by using shift and drag while in translation tool (same at it is for example in 3DS Max). Just select the instance you want to clone, open the translate tool (Control + T by default), hold shift key down and drag with the mouse using one of the gizmo axes. Instead moving the instance, a new one is cloned and moved.
Now, the only problem is that the property tables are not duplicated (this was an omission i think). I will have it fixed and added in the next patch.
cmusch
PostPosted: Mon Dec 17, 2007 9:58 am    Post subject: Reply with quote
Thanks a lot!!
PostPosted: Tue Dec 18, 2007 5:44 pm    Post subject: Reply with quote
You can access the latest patch (01.10.19) which adds this feature (copying property tables while cloning objects). Let me know if you have any problems.
