 property array syntax « View previous topic :: View next topic »
cmusch
PostPosted: Sat Dec 15, 2007 5:15 pm    Post subject: property array syntax Reply with quote
Hello!
Could you be so kind and post the syntax for defining arrays in a property table? The in-app description unfortunately doesn't fit into the label area and is truncated.
regards
cm
PostPosted: Tue Dec 18, 2007 5:47 pm    Post subject: Reply with quote
Actually there was an error that didn't let you specify an array. Now all is fixed (in the latest patch, 01.10.19). The syntax is:
No of elements|selected element|type of elements|elem1 ... elemN
Example:
3|1|double|1.2|3.1415|2.00
This creates an array of 3 doubles with the second one (index 1) selected by default.
As you will see, in the latest patch the dialog was modified so the syntax is properly viewed now. The SDK was also modified so you can now add and get array fields (there are other types actually added by the new SDK: double, short, ushort, char, uchar). See the SDK documentation for details.
cmusch
PostPosted: Wed Dec 19, 2007 10:07 am    Post subject: Reply with quote
Thanks a lot, works like a breeze.
