 Example Scene doesn't work? « View previous topic :: View next topic »
DeanoC
PostPosted: Sun Nov 11, 2007 3:18 pm    Post subject: Example Scene doesn't work? Reply with quote
I've downloaded MountainSmall supposely a Grome Standard example but it doesn't work for me. I get an error popping up saying it wasn't saved in by Standard and some details may be lost, which I click okay but when loaded there is no terrain.
There also library errors, I managed to include a few so I can see some tree but still very broken with regard the landscep?
How exactly do you load the samples?
The reason I want to is, i'm tracking down another 'oddity' in our scenes but don't know if its a bug in Grome terrain rendering or something we are doing wrong (i'm seeing clamped texture coordinates for a diffuse texture layer which is odd (makes rotation and scaling virtually useless?) )
Console log below...
Thanks for any help.
Deano
Console Log
Security: error code 200
Opening scene workspace: MountainSmall
Maximum number of material layers reached in standard edition!
Error: [Reading layer material]
Invalid file format: the heightmap layer terrain stream loading failed for "TerrainZone (17)"
Error loading terrain data zone "TerrainZone (17)" from project "Terrain"
Invalid file format: the heightmap layer terrain stream loading failed for "TerrainZone (6)"
Error loading terrain data zone "TerrainZone (6)" from project "Terrain"
Invalid file format: the heightmap layer terrain stream loading failed for "TerrainZone (10)"
Error loading terrain data zone "TerrainZone (10)" from project "Terrain"
Invalid file format: the heightmap layer terrain stream loading failed for "TerrainZone (7)"
Error loading terrain data zone "TerrainZone (7)" from project "Terrain"
PostPosted: Mon Nov 12, 2007 7:24 am    Post subject: Reply with quote
Yes we know about the problem of the sample maps and the standard edition. The next patch will fix this (tomorrow is to be released).
About your 'oddity', can you send me more information. I may be able to help you. A diffuse texture layer (i.e. a layer with mask) should not have the texture coordinates clamped.
PostPosted: Tue Nov 13, 2007 7:38 am    Post subject: Reply with quote
Hi, a new patch was released yesterday including fixing the above map you've mentioned. Please download it again, now it should work for standard version.
