 SurfaceInstance doesn't have a SurfaceTemplate « View previous topic :: View next topic »
DeanoC
PostPosted: Thu Nov 08, 2007 4:21 pm    Post subject: SurfaceInstance doesn't have a SurfaceTemplate Reply with quote
I've got a SurfaceInstance from a terrain zone thats returning null for its SurfaceTemplate, is that a legal situation or a bug?
Its not very intuitive that an instance can not have a template. The documentation say "An instance is a space localization (via a matrix) to a surface template", which to me implies that an instance can't exist without a template.
As I was hoping to grab the vertex and index data from the template, but if it doesn't have one i'll have to compute from the heightfield data directly, which seems more error prone...
Thanks,
Deano
DeanoC
PostPosted: Thu Nov 08, 2007 5:06 pm    Post subject: Reply with quote
Some additional info
csdk::iGeomEntityInstance* geom = terrain_zone->GetGeomEntityInstance();
csdk::t_readonly_array<csdk::iSurfaceInstance*>* surfaces = geom->GetSurfaces();
for( uint surfNo = 0;surfNo < surfaces->No();++surfNo )
    csdk::iSurfaceInstance* surface = surfaces->Elem(surfNo);
    csdk::iSurfaceTemplate* templat = surface->GetTemplate();
templat == 0
However using code from ExpOSG
iGeomEntityTemplate *geom_templ = terrain_zone->GetGeomEntityTemplate();
if(geom_templ)
   t_readonly_array<iSurfaceTemplate*>* surfaces = geom_templ->GetSurfaces();
      csdk::iSurfaceTemplate* templat = surfaces->Elem(surfNo);
templat = valid interface;
Works, which to my eye looks like a bug, they should be both equivilent i think?
Anyway I have a working solution, so i'm happy Smile
Thanks,
Deano
PostPosted: Fri Nov 09, 2007 9:01 am    Post subject: Reply with quote
Yes, it is a confirmed bug. Thank you for the report. The issue is fixed and it will be present in the next patch.
Also to be noted that two method may return two different interface pointers as csdk::iSurfaceTemplate* (even though internally they refer to the same data). So you must not check the pointers for equality (even though I don't know why you would do that) to see if they refer to the same data. Usually the SDK is reusing the interfaces so they have the same pointers, but in this case temporary interfaces are allocated.
