 Heightmap export « View previous topic :: View next topic »
greedo
PostPosted: Mon Oct 01, 2007 1:16 pm    Post subject: Heightmap export Reply with quote
Is it possible to create a greyscale heightmap of the terrain?
PostPosted: Tue Oct 02, 2007 6:22 am    Post subject: Reply with quote
You can export 16 bit RAW or PNG grayscale heightmap (from the text exporter plugin). This contains the data in 16 bit (and not the normal 8 bit associated with normal greyscale images). You can convert the exported images to 8 bit with programs like Photoshop but you will loose terrain precision.
You can also create your own plugin to write 8 bit heightmaps (it is pretty easy as you can use 16 bit export as example).
In general you don't want to use only 8 bit because this is not enough to represent height details, that's why we didn't included a 8 bit export out of the box (and we preferred 16bit).
Regards
greedo
PostPosted: Thu Oct 04, 2007 8:19 pm    Post subject: Reply with quote
Thank you, i don't know how could I miss it.
