 terrain/objects « View previous topic :: View next topic »
greedo
PostPosted: Tue Aug 28, 2007 10:18 pm    Post subject: terrain/objects Reply with quote
Is it possible to save the terrain and the placed objects into two separate files after a scene has been put together?
We need that because of the different application of shadows and LOD for objects and terrain in the engine.
PostPosted: Wed Aug 29, 2007 5:57 am    Post subject: Reply with quote
To be them in two separate files at export? If so, what exporter do you use?
greedo
PostPosted: Tue Sep 04, 2007 6:52 pm    Post subject: Reply with quote
Kind of. We use the standard collada exporter.
PostPosted: Wed Sep 05, 2007 6:05 am    Post subject: Reply with quote
Yes, the simplest way is to add an option in the current COLLADA exporter to not export terrain (there is already one that indicate not to export objects). So you can trigger the export two times with different options (one to export only terrain, and one only objects). I think this option will make it in the next patch.
greedo
PostPosted: Wed Sep 05, 2007 7:07 pm    Post subject: Reply with quote
Thank you!
