 GetPropValue usage « View previous topic :: View next topic »
mkolb
PostPosted: Thu Aug 23, 2007 7:09 am    Post subject: GetPropValue usage Reply with quote
I want to retrieve the user properties in the SDK for a custom exporter plug-in. However I can't manage to create the appropriate variable to save the value in it.
This is what I've got so far:
t_char** Ogremesh = new t_char*[128];
   iPropertyTableOwner *prop_owner = (iPropertyTableOwner*)inst->OpenSubinterface(
      g_sdk_root->GetTypeId(iPropertyTableOwner::TypeString()));
   prop_owner->GetPropertyTable(0)->GetPropValue(0,0,(void*&)Ogremesh);
I am a bit weak with pointer-to-pointers(or how you might name **), so could please someone give me a short hint on how to initialise the variable for a string property?
Regards
PostPosted: Thu Aug 23, 2007 11:23 am    Post subject: Reply with quote
Yes, there is small bug in the SDK that don't let you get a string. Please download the today patch (1.10.01) that fixes this problem.
The SDK is using pointer to pointer so it doesn't have to allocate the string or for you to have it previously allocated (without knowing the string size).
Now, as stated in the function documentation, the GetPropValue will accept a pointer to a pointer of t_char and fill it with the pointer to the internal string kept by the engine. So the code may look like this:
t_char* OgremeshPointer;
   prop_owner->GetPropertyTable(0)->GetPropValue(0,0, &OgremeshPointer);
// Now we have our pointer filled, is time to copy it into one of our strings.
if(OgremeshPointer)
   t_char* Ogremesh = new char((gStrLen(OgremeshPointer)+1)*sizeof(t_char));
   gStrCpy(Ogremesh, OgremeshPointer);
   // Do something with Ogremesh string.
   delete(Ogremesh);
You can also use OgremeshPointer directly as long as you don't modify the string (because it is pointing to the internally allocated one). You can modify it with SetPropValue.
To be noted that if you add this as a resource property and have storage format plugin for ogre meshes for example (to read ogre meshes directly) you can access the ogres meshes directly through the property, not only its name.
mkolb
PostPosted: Thu Aug 23, 2007 11:43 am    Post subject: Reply with quote
Thank you for your reply,
for the sake of correctness and others possibly others having the same problem I have to point out that the line
should be
t_char* Ogremesh = new t_char((gStrLen(OgremeshPointer)+1)*sizeof(t_char));
PostPosted: Thu Aug 23, 2007 11:47 am    Post subject: Reply with quote
Ah, you are right, actually it should be
new t_char[gStrLen(OgremeshPointer)+1];
or
(t_char*)malloc((gStrLen(OgremeshPointer)+1)*sizeof(t_char)];
Thanks for pointing that out.
