 User-defined object properties « View previous topic :: View next topic »
cmusch
PostPosted: Fri Aug 03, 2007 9:58 am    Post subject: User-defined object properties Reply with quote
Hi!
Currently, as far as I can tell, there is no possibility to specify anything else but a matrix transform for an object. I think it is vital that there be some way to attach user-defined properties to the placed meshes.
In the simplest case, this would be just a collection of name-value string pairs, editable in a simple table. The storage plugin could set default values when loading an object, which the user then can change and the export plugin can read and act upon.
A more comfortable way would be to have different primitive datatypes, which can have their range / possible values specified, so the user can chose from a listbox (e.g. true/false for a boolean, or different values from an enumeration), or change values via a slider.
Without this feature, the flexibility of the tool is severly limited in my opinion.
greetings
chris
PostPosted: Fri Aug 03, 2007 10:03 am    Post subject: Reply with quote
Already in work and will be released shortly Wink
We know this is a very important feature.
cmusch
PostPosted: Fri Aug 03, 2007 10:14 am    Post subject: Reply with quote
Great to hear this Smile
Any hint on the approximate timeframe of "shortly"? One month? One week? One day? Wink
regards
chris
PostPosted: Fri Aug 03, 2007 10:21 am    Post subject: Reply with quote
I would say max 2 weeks.
greedo
PostPosted: Fri Aug 24, 2007 6:39 pm    Post subject: Reply with quote
Quote:
Define and assign properties for your game's:
- AI - Game triggers
- Lighting - Sound sources
and more
Love you guys! Very Happy
