 Tips & tricks « View previous topic :: View next topic »
Mihai
PostPosted: Mon Jun 11, 2007 3:02 pm    Post subject: Tips & tricks Reply with quote
Tips & tricks
Hi everybody,
Here are some tips and tricks for a 1024 x 1024 terrain zone with 10 m tile
I am using 4 layer of high map and some brush tweaking (with a crater as a mask )
The first layer of high map is a simple fractal noise ( rocky3 preset) with some small modification as you can see in the pictures below
The second layer it’s also a fractal noise ( eroded mountains from presets ) leveled with the brush in some aria (as you see in the pictures)
The third layer is an hydraulic erosion with water amount and soil hardness on minimum
The four and final layer is hydraulic erosion with water amount one quarter and soil hardness on maxim
IN THE FORTH LAYER I LEVELD THE FLAT ARRIA AND ADD SOME DETAIL WITH THE BRUSH (with a crater as a mask)
Mihai
PostPosted: Mon Jun 11, 2007 3:10 pm    Post subject: Reply with quote
Time to make this high map 15-20 minutes
Best Regards
Mihai Daranga
Mihai
PostPosted: Wed Jun 13, 2007 12:39 pm    Post subject: Transfer of hightmap terren feature to separate layer Reply with quote
Hi everybody,
Here is another tip.
In this post you will find new tricks from time to time.
