 Collada Export « View previous topic :: View next topic »
Sparticus
PostPosted: Tue May 06, 2008 5:32 am    Post subject: Collada Export Reply with quote
Is there a way to only export the selected zones with Collada, like with OSG? When trying to export a 10x10 with in Collada, I get an error when i run out of memory (2gigs) and then the program crashes. Error:
Core Engine Exception Handler
Exception C0000005 detected!
Not sure if this is considered an actual bug or a limitation of that particular exporter?
Thanks for the help !
[/img]
PostPosted: Tue May 06, 2008 6:37 am    Post subject: Reply with quote
Hi, we will add an option to the exporter to save only the selected zones. Should not be hard to make. I will post you an update soon.
For now you can do it with a trick: delete zones you don't want to export, perform export, undo (to undelete the zones), repeat etc.
And another better method would be to swap out all the zones, and then call the exporter. The exporter will swap in and out zones as it exports them.
PostPosted: Tue May 06, 2008 7:24 am    Post subject: Reply with quote
Hi, you can download an updated version of COLLADA exporter with export only selected option from here:
http://www.quadsoftware.com/storage/ExpCollada.rar
Just unrar it into the Plugins folder from Grome. Make sure you use the latest Grome version (1.20.09) !
Regards
Sparticus
PostPosted: Wed May 07, 2008 3:41 am    Post subject: worked ! Thanks Reply with quote
The new pluggin works great ! Your support is amazing Very Happy
khalua
PostPosted: Fri Dec 07, 2018 8:04 am    Post subject: Judi Poker Online Terpercaya Reply with quote
Situs poker online terpercaya dan terbaik ditahun 2019, mempunyai http://qiuceme.site banyak jenis permainan Bandar ceme online Yang paling perlu http://qiuceme.poker diketahui dari permainan bandar ceme online terpercaya ini yaitu kalau permainan ini mesti fairplay pada player vs player yang dan http://capsaqiu.live juga mempunyai memakai rekening indonesia seperti bank bca, bni, bri, serta mandiri. perlayanan customer service 24 jam yang melayani kita dengan cara customer care yakni menjawab pertanyaan anda hingga anda mengetahui benar. yang ke-4 yaitu melindungi data http://qqpokerceme.online dari tiap-tiap anggota supaya tetaplah terbangun serta kerahasian juga dijaga dengan aman. Dari yang kami jabarkan di atas kalau bandar ceme online bisa pula dimainkan oleh tiap-tiap anggota yang join dengan kami. Dengan permainan ceme online yang berada di situs poker online Situs Bandar ceme online terpercaya uang asli. Bandar terpercaya, situs poker online adalah di antara website bandar ceme Online terpercaya di indonesia yang memanfaatkan duwit asli rupiah. Beberapa bettor yang bahagia bermain di casino tentu begitu kesusahan andaikata poker online terpercaya pingin bermain. Saat ini sudah ada untuk beberapa judi online ceme 99 yang berada pada indonesia. Di mana permainan judi ini dimainkan dengan online seperti permainan Judi Ceme Online. Saat ini judi bandar bisa dimainkan memanfaatkan uang asli indonesia. Permainan poker online ceme, ceme ini pada mulanya dimainkan di kasino didunia. Domino http://ceme-online.space adalah permainan yang dimainkan minimum oleh dua orang serta maksimum oleh delapan orang. Seperti namanya game domino ceme 99 ini memanfaatkan kartu domino http://172.96.186.210 jadi alat permainannya. Kartu domino http://kejupoker.com terbagi dalam 28 kartu yang miliki bulatan bulatan angka atau dot yang berlainan di tiap-tiap kartunya serta
