 object alpha texture & shadowmap « View previous topic :: View next topic »
imcgames
PostPosted: Mon Jul 09, 2007 9:23 am    Post subject: object alpha texture & shadowmap Reply with quote
Want to make ‘shadowmap’ to make a place of tree and grasses using “grome”
Hope to can make a ‘shadowmap’ which can get alpha effect from object.
Let me know if there’s any way can make this way
And let me know when you’ll update grome
PostPosted: Mon Jul 09, 2007 10:05 am    Post subject: Reply with quote
For now Grome is using ray picking to generate the shadow. The generated shadow is pretty simple in the sense that it is not using complex lighting and shadowing algorithms (global illumination, penumbra generation). And, yes, it is not using the alpha from the objects to detect the actual object visible shape.
In the future we will make more complex shadowing algorithms but I cannot give you a certain date (and I bet we will tend to implement a dynamic implementation using shadow maps than a static baked texture).
The solution is not simple enough to be easily implemented (the shadow techniques are a vast domain). The best solution for you, for now, is to generate the terrain shadow in different modeling application that supports more complex lighting models (like 3DS Max 9 for which you can import the geometry as COLLADA and generate the shadowmap on the planar mapping of the terrain).
imcgames
PostPosted: Tue Jul 10, 2007 2:02 am    Post subject: Reply with quote
Thanks for the quick response.
