 Text Exporter - Buffer overrun detected! « View previous topic :: View next topic »
imcgames
PostPosted: Mon Jun 11, 2007 12:50 am    Post subject: Text Exporter - Buffer overrun detected! Reply with quote
When I using text export, it closed with blew this message.
This situation happens just this project that we're using now.
After we tested it, we confirmed this problem isn't concerned about [position].
So we supposed that [dimensions] was from 1edge to 1centimeter
And then we could work it that 256tile had 1km size.
It is possible that working is similar size 3dsmax working centimeter.
If problem is [dimensions] setting, I 'd like to know how to solve the problem.
Thank you..
== Zone Creation Setting ==
[Terrain resolution]
- Tiles No: 256
[Terrain dimensions]
- Edge : 100000.00
- X Zones : 1
- Z Zones : 1
[Center position]
- X : -450000
- Y : 0
- Z : 250000
PostPosted: Mon Jun 11, 2007 6:52 am    Post subject: Reply with quote
Hi, can you please try to download the latest version of the plugin from here:
http://www.quadsoftware.com/storage/ExpTxt.plug
Just copy it in the Plugins directory over the old one. It should be used with version 01.08.10 of the editor.
Let me know if this resolves your problem.
imcgames
PostPosted: Tue Jun 12, 2007 12:56 am    Post subject: Reply with quote
HI, the same situation is occured continuely
PostPosted: Tue Jun 12, 2007 6:57 am    Post subject: Reply with quote
Can you please send me the map you are having problems with?
I can send a FTP location for that.
imcgames
PostPosted: Wed Jun 13, 2007 4:24 am    Post subject: Reply with quote
HI, It does not seem that it happens only in a specific map.
That phenomenon also occurs in the new map that is applied with "Edge=100000.00".
PostPosted: Wed Jun 13, 2007 6:29 am    Post subject: Reply with quote
I see, first I thought it happened when you select OK.
Bug is resolved. For a quick fix you can download the text exporter from here:
The fix will be present in the next patch (01.08.12) at the end of the week.
Thank you for your report.
