 64bit Grome crashes « View previous topic :: View next topic »
makit3d
PostPosted: Wed Oct 26, 2016 2:45 pm    Post subject: 64bit Grome crashes Reply with quote
After re-installing and discovering that the activation process wouldn't initialize unless I used the 32bit version of Grome I thought I might be able to use the 64bit version.
So far the 64bit version crashes (just disappears with no error codes or warning dialog boxes) during new file creation.
PostPosted: Sun Oct 30, 2016 6:27 pm    Post subject: Reply with quote
Do you have some disk utility installed (like symbolic link, network utility etc)? I do notice that 64 bit file dialog crashes when some utilities are installed.
You can also try to send me the console logs (files in Builder/Bin64/Logs folder) via email (licu at quadsoftware.com) and I will have a look.
