 Road - Space between road and landscape « View previous topic :: View next topic »
Eddy71
PostPosted: Mon Oct 28, 2013 3:43 am    Post subject: Road - Space between road and landscape Reply with quote
I obtain space between road and landscape, when I use Adjust and move a point to the top. Road Layer is linked to the Road. What is the problem ?
http://www.hostingpics.net/viewer.php?id=435117Capture10.jpg
http://www.hostingpics.net/viewer.php?id=424287Capture12.jpg
PostPosted: Mon Oct 28, 2013 7:11 am    Post subject: Reply with quote
That's strange. Do you have multiple layers of heightmaps?
Can you send me a sample map with the issue? You can use my direct email address (licu at quadsoftware.com).
Eddy71
PostPosted: Mon Oct 28, 2013 11:39 am    Post subject: Reply with quote
There is only one heightmap layer.
I sent you the map file.
Eddy
PostPosted: Mon Oct 28, 2013 2:44 pm    Post subject: Reply with quote
Thank you for the test files.
I've looked over your map and indeed there is a difference (had to disable the mesh layers which probably were computed before the road was placed). I've talked with the programmer dealing with roads and he said that the heightmap is too coarse (resolution too low) and that the road leveling has some errors (it is using shaders on the GPU to do the job). We can try to further improve the precision but best is to just use a higher res for your heightmaps (you can easily change it, just select the zones, arm the heightmap layer if not already so, and then open Resample tool from Heightmap tools section). If I use for example 512 then the heightmap will follow the road as expected. There is still a small gap but this I think was intentionally introduced, in order to avoid depth buffer errors (z fighting).
In the end, if you are using simplified meshes then you can just recompute them at any resolution so this increase at hightmap should not affect your final result. If you are using heightmaps at export, then you can just resample them at lower res before exporting.
I hope this helps. Let me know if this fixes your issue.
Eddy71
PostPosted: Mon Oct 28, 2013 3:27 pm    Post subject: Reply with quote
Increase the resolution to 512 did the trick. Smile
No problem for the simplified meshes, result is perfect. (UDK mobile usage)
Thanks for your help,
Eddy
http://www.hostingpics.net/viewer.php?id=777085Capture01.jpg
