Posted: Wed Feb 01, 2012 4:05 pm Post subject: |
I see. Can you send me an exported dae file? You can send it directly to my email (licu at quadsoftware dot com).
Adrian Licu |
Lillarpy |
Posted: Mon Feb 06, 2012 2:21 pm Post subject: |
ALicu wrote: |
Adrian Licu |
Hi.
I would love to but unfortunately our exported dae files are on 950 meg and gmail will only let me send 25meg. I will try to export an dae file within that requirement tonight.
Another problem!
In my simplified versions I get nasty holes in the terrain mesh. Is that something I can prevent ? It is a simplified version with 800 vertices-setting.
Picture:
http://tinypic.com/r/2dw6yj4/5 |
Posted: Mon Feb 06, 2012 2:26 pm Post subject: |
About the hole in the simplified meshes. If you apply the simplification algorithm with the same parameters you should not get any holes at the border of the zones. If you get, then it must be a bug. You can try to send me a simple file with 2 zones with the holes present (and also tell me the parameters you've used for simplify tool). I will debug the issue.
If the files are too big, let me know (send me an email to licu at quadsoftware.com) and I will send you a FTP account to upload the data to.
Adrian |
