Post new topic  Reply to topic Goto page Previous  1, 2, 3
 Unreal Development Kit « View previous topic :: View next topic »
PostPosted: Fri Feb 05, 2010 1:33 pm    Post subject: Reply with quote
Oh I see. Then your errors are caused by the fact that each terrain zone is scaled based on its local maximum and minimum (which explains the difference in scaling). These errors will not be present for the UDK exporter which will deal the scaling uniformly for the entire scene (the general exporter is meant for other tasks, where the entire scene raw is needed).
For now you can use the text exporter. Yes, I know it is strange that it also saves raw files but up until some time ago it was the only way to save raw files. Raw files were added to this text exporter as an option until General exporter was introduced. Just press "Export heightmaps as 16 bit raw/png" and press the Options button next to it. From there select "Create an image for each zone" and raw format.
I hope to have the UDK exporter soon. I've already exported with it but I need to make its UI, help and do some testing.
Zykomaniac
PostPosted: Fri Feb 05, 2010 1:45 pm    Post subject: Reply with quote
Yeah, ok I will try that then.
EDIT: Awsome, text exporter work perfectly ^^
PostPosted: Sat Feb 06, 2010 6:31 pm    Post subject: Reply with quote
I am glad to announce you that today I took some time to complete the exporter. You can found about it here:
http://www.quadsoftware.com/forum/viewtopic.php?p=2342#2342
This is first version so some things may not go as planned. I didn't had time to test it inside UnrealEd but it seems to produce correct files (read by G16Ed). Let me know if you have any issues.
joskj
PostPosted: Mon Feb 08, 2010 3:12 pm    Post subject: Reply with quote
Zykomaniac wrote:
Just to catch on regarding anti-clock and clockwise, as you said it will depend how you do it on Grome, if you rotate anti-clockwise, you need to export anti-clockwise, if you flip it 180 around, you need to export 180 turn around aswell.
But you mentioned you could rotate the texture from 1 material accordingly in udk to reduce amount of materials is true aswell. or rather, make two terrain layer materials use the same texture material, then make 1 of the terrain layers materials rotate itself 90 degrees/-90. which actually reduces cluttering of materials in UDK.
And yeah UDK converts the texture on import so in the end they are all the same format, else I'd bet there would have been info of what format it was in UDK. Smile
UDK manual isnt complete regarding formats then, because you can import DDS as well ^^
Wink was on your homepage yesterday you see joskj ; P
Finally got around to download the latest version of UDK, but I still cant seem to find where to import a DDS texture into UDK. Would realy apriciate any tips on this Zykomaniac.
Zykomaniac
PostPosted: Mon Feb 08, 2010 8:42 pm    Post subject: Reply with quote
*scratches head* I dont understand a thing, I remember having DDS in the import list, but since that when I listed what could be imported I've reinstalled January Version but now it isnt in the list anymore..*scratches head again*
joskj
PostPosted: Tue Feb 09, 2010 7:56 am    Post subject: Reply with quote
Oh well, no bigg deal, isnt a problem converting the images until we get more options in the exporter.
PuckerFactor
PostPosted: Mon Sep 27, 2010 6:16 am    Post subject: Reply with quote
So what"s the progresses on this? ....no more info since Feb 2010....Have you guys given up on this?
PostPosted: Mon Sep 27, 2010 6:44 am    Post subject: Reply with quote
You can use the current version of the plug-in as described here:
to export data from Grome.
Then use the tutorial written by joskj. The current solution is usable. Using it you can get multi layer, multi zones Grome scenes into Unreal.
Arthr702
PostPosted: Mon Jan 02, 2012 4:23 pm    Post subject: Reply with quote
Hey guys,
are there an working version of the exporter for Grome 3? With the old one I got an parsing error during the start of Grome.
PostPosted: Mon Jan 02, 2012 4:42 pm    Post subject: Reply with quote
Grome SDK is backward compatible at source level so one can just recompile the plugin to make it work with latest Grome SDK version. I will recompile the plugin and put it on site tomorrow once I am back at the office. I will let you know when the version is on site.
PostPosted: Tue Jan 03, 2012 6:34 am    Post subject: Reply with quote
You can find the updated UDK exporter compiled for Grome 3 here:
http://www.quadsoftware.com/storage/ExpUDK_Grome3.zip
Just unpack the archive and then copy the two .plug files from unpacked Plugins folder into Plugins directory where Grome 3 is installed.
baroque2k
PostPosted: Fri Aug 11, 2017 4:17 pm    Post subject: Reply with quote
How can i download UDK exporter?
Link a seems to be broken.
PostPosted: Fri Aug 11, 2017 6:44 pm    Post subject: Reply with quote
Hi, the following link was now fixed:
http://www.quadsoftware.com/storage/udk/ExpUDK_Grome311.zip
It should work with Grome 3.1
Post new topic  Reply to topic Goto page Previous  1, 2, 3 Page 3 of 3
