 Object Creation « View previous topic :: View next topic »
Ingot
PostPosted: Thu Mar 22, 2007 1:36 am    Post subject: Object Creation Reply with quote
Is there a tutorial somewhere that will tell me how to add my
direct x or 3ds objects to my Grome terrain? I noticed that
the trees that come with the demo are in .lod format.
I know what level of detail is... I just don't understand how to
import other formatted objects.
PostPosted: Thu Mar 22, 2007 7:45 am    Post subject: Reply with quote
LOD is a native Grome format. It is actually a LOD chain (multiple other objects linked together in a single lod and shown at various distances). You can create LOD chains with the help of the Package Browser but you will need the other objects to add to the chain.
You can import other formats with the help of the SDK (which is present in the full version). So if you have the SDK you can write your own object format (or use one already present like COLLADA to which Max, Maya, Blender are able to save). Then you can create LOD objects from this formats (so basically you can, for example, setup Max objects as LODs).
So for now (in the demo version) you can test only with the provided objects.
Ingot
PostPosted: Thu Mar 22, 2007 7:48 am    Post subject: Direct X Reply with quote
Can I import direct x and 3ds files into grome?
PostPosted: Thu Mar 22, 2007 7:50 am    Post subject: Reply with quote
At release time, these formats will not be available directly. You can convert them (and there are multiple methods) to COLLADA, for example, and browse and read them directly in Grome. We will add this formats shortly after release (3ds, Maya .obj).
Ingot
PostPosted: Thu Mar 22, 2007 7:53 am    Post subject: direct x Reply with quote
Ok,
I have a game engine that is written in direct x.
Will I be able to export my grome levels to direct x format?
PostPosted: Thu Mar 22, 2007 8:02 am    Post subject: Reply with quote
Once you have the SDK you can import and export from/to any format. You will be able to write your own plugins (which is pretty simple if you are a programmer as lots of examples with full source code are provided). With time we will also add support for all common formats (and .x is one of it) but I cannot give you an exact date.
