 Error in swap script « View previous topic :: View next topic »
duke2
PostPosted: Fri Jun 26, 2009 10:55 am    Post subject: Error in swap script Reply with quote
The SwapProcessing script doesn't work for me when the zones it's trying to select (in FindResidentZone are swapped). So, for example, if my zone is called "Raw Zone 0 0", it won't find that if it is swapped. If it is unswapped, it will find it, which somewhat defeats the purpose of the script.
PostPosted: Mon Jun 29, 2009 2:44 pm    Post subject: Reply with quote
Strange, the gGetFirstNodeByName should find the name if it swapped or not. I will try now the script and get back with a fix.
PostPosted: Wed Jul 01, 2009 8:15 am    Post subject: Reply with quote
I've tested the script and is processing the swapped zones. Can you send me a sample map you are trying to use (you can use licu at quadsoftware.com email address, or let me know if the file archive is bigger than 10MB, so I will send you a FTP account)?
The problem that I see though with this approach is that seam stitching is not working correctly if tools are applied on a single zone at once (the current processed zone will stitch to zero since its neighbor are all swapped or are unprocessed). I will think of a solution. Maybe a script to apply on 3 by 3 zones, or a way to deactivate stitching.
