Post new topic  Reply to topic Goto page Previous  1, 2
 is this normal? « View previous topic :: View next topic »
mrhiggens
PostPosted: Thu Apr 09, 2009 8:36 pm    Post subject: Reply with quote
i seems i cant open the ones with big mask sizes ( the 500 tiles ones) but the ones will small mask sizes i can. i try opening in ps and paint btw they both give some sort of error.
PostPosted: Thu Apr 09, 2009 8:49 pm    Post subject: Reply with quote
Oh, I see. So the ones with big tile size I think they are too big to be opened in conventional paint programs (since they were exported with wrong resolution step size and the exporter produced unnecessary big images).
I recommend using a smaller tile size anyway (10 for example). You can think of the units as meters, cm, feet etc. So for example if you need 1 meter per tile you can use 1 instead of 10. Approximate the tile size to fit your needs. As long as is in the 1 - 100 range you will be ok with the default presets values. But make sure you use the same size for resolution when exporting (so if you use a tile size of 1, use 1 as resolution step etc). Same for images. Make sure your masks/color images export resolution matches the size of a pixel in world space.
Post new topic  Reply to topic Goto page Previous  1, 2 Page 2 of 2
