 Presets are now gone ? « View previous topic :: View next topic »
Spikelife
PostPosted: Sat Dec 20, 2008 9:20 pm    Post subject: Presets are now gone ? Reply with quote
Also, after installing 12/5 update the presets are now gone ?
PostPosted: Sun Dec 21, 2008 9:13 am    Post subject: Reply with quote
I've just checked the setup scripts and the presets are there while if you have previous presets they are not overwritten by installing on top of older build. What presets are you referring to? From what tools? And also your own presets or the default ones that come with Grome.
You can find the default presets for Professional version here:
http://www.quadsoftware.com/storage/DefaultProEdition.presets
Just import then using Tools -> Manage Tools Presets from the menu.
Before you do the import please send me the following file:
/Builder/Scripts/Configs/default/configuration.registry
This should contain your presets. I want to check out if the format is valid or not.
Spikelife
PostPosted: Sun Dec 21, 2008 4:10 pm    Post subject: Reply with quote
Will do .. ty very much.
