 1.20.26 collada exporter only exports 1 color layer « View previous topic :: View next topic »
alienheretic
PostPosted: Sun Nov 09, 2008 10:14 am    Post subject: 1.20.26 collada exporter only exports 1 color layer Reply with quote
i have 2 color layers 1 for red green blue black and 1 for shadow map
collada only exports lowest texture in tree
so i get no shadowmap export unless i delete the first color layer
then export
then hit undo a few times to get it back
alienheretic
PostPosted: Sun Nov 09, 2008 8:06 pm    Post subject: corection Reply with quote
it does work corectly if you uncheck export only selected zones
PostPosted: Mon Nov 10, 2008 8:15 am    Post subject: Reply with quote
Are you referring to the fact that images are not expoted in the save folder? Or that they are not referred inside the COLLADA file?
I've just tested the exporter and it does save all the image files (not matter if export only selected is checked or not). But indeed only the first one is referred inside the COLLADA file. This is because there is not standard way to represent multiple layers of terrain in collada file. So that's why collada export is suitable mostly for heightmap and one image. For complete terrain format you should use your own format or if you use other engines (OSG, Torque) use their specific export plugins.
You can however reproduce Grome layers (at least some types) in other modeling packages. In 3DS Max for example you can use composite material or FX. More on this issue in this thread:
http://www.quadsoftware.com/forum/viewtopic.php?t=162
Let me know what application/engine you are using and I may be able to indicate the best formats.
