 What happened to Export plugins? « View previous topic :: View next topic »
AD_Dennis
PostPosted: Fri Aug 01, 2008 12:05 am    Post subject: What happened to Export plugins? Reply with quote
I just downloaded the latest version of Grome and now my TGEA and modified TGEA exporter no longer show up in the export Save As... dialog. Did the exporter interface change?
AD_Dennis
PostPosted: Fri Aug 01, 2008 12:12 am    Post subject: Export Problem - Update Reply with quote
I was using version 1.20.20 when the problem occurred. I reinstalled 1.20.14 and all of the exporters show up again.
PostPosted: Fri Aug 01, 2008 7:57 am    Post subject: Reply with quote
Hello Dennis,
Version 1.20.20 introduced new things at the SDK interfaces that necessitate version to change (the old plugins will not be started by the new SDK). Usually you just need to recompile the plugins. We always indicate this thing in the console log.
About the TGEA plugin, there is a new version posted (1.21, right after the Grome 1.20.20 came out) that will work with the new build:
http://www.quadsoftware.com/index.php?m=section&sec=product&subsec=editor&target=editor_torque
Please use this version with grome 1.20.20 (as several bugs were resolved with the latest build).
AD_Dennis
PostPosted: Sat Aug 02, 2008 7:39 pm    Post subject: Reply with quote
Thanks ALicu, I merged the new importer and SDK code with mine and it works fine.
